To ensure the integrity of the corporate firewall and to
provide an additional layer of security for data flowing between the mobile
device and the MobiControl Manager(s) and Deployment Server(s) over public networks, SSL Communication Mode is
available to provide encrypted communication. When SSL is not enabled MobiControl encrypts all communications
using proprietary algorithms. SSL provides the additional benefit of standards-based authentication and
encryption security.
To enable SSL communication for a device or group of devices,
select Connection Security Policy from the MobiControl Security Center. Please see the Device Security and Control page.)
This dialog box allows you to enable SSL communication for specific devices. For
example, one group of devices which are in your warehouse do not need to use SSL,
whereas you do want another group of devices that are in the field and
communicating over public networks to use SSL.
Configure SSL device settings dialog box
For assistance with Override Settings Click Here.
The dialog box above allows you to specify the means by which you wish to have
the MobiControl system deliver the Device Agent's certificate and private key to
the device.
Note:
When SSL is enabled, MobiControl acts as its own
certificate authority. It generates certificates for the MobiControl entities
(Manager, Deployment Server, and Device Agents).
The table below summarizes the three available options for delivering and
installing the device's MobiControl certificate:
Option |
Description |
Automatic delivery and
silent installation of certificates |
When this option is selected the Deployment Server will automatically
deliver the certificate and private key for the device when the device
connects. No user interaction is required.
prompt for password before installation on device |
This option provides additional assurance that only authorized devices
receive an SSL certificate and private key. When this option is selected,
the Deployment Server will prompt the device user to enter the password
specified in this dialog box before it delivers the certificate and
private key.
The device will be able to connect and stay online even if a password
is not entered, however in this state the device will not receive any
packages, or execute file synchronization. The administrative user can
remote control the device to assist the device user with entering the
password to retrieve the device certificate.
The user will be given several chances to enter the correct password.
If the user enters an incorrect password five times, and the Keep Device
Connected check box is not selected, the device will be disconnected
and disabled. To re-enable the device right-click on it in the device tree
and select Enable. If the Keep Device Connected check box is
selected, the device will remain online, and as described above, will
not be eligible for package delivery or file synchronization but can be
remote controlled.
Manual Installation
(No automatic delivery or installation) |
When this option is selected certificates and
private keys will not be automatically delivered to the devices. The
certificate and private key must be exported (*.pfx file), and delivered to the
device by some means. This could be via email, file transfer, etc.
Note:
Importing certificates is only supported on Windows Mobile 5
devices and Windows desktop clients (Windows 2000/XP).
In all the cases above, the Device Agent stores the
certificate and private key into the Windows operating system's personal certificate store. The
MobiControl Root CA certificate, on the other hand, is stored in the operating system's trusted root
certificate store.
Manual Installation
Export Device Certificate dialog box
When this option is selected, the certificate and
device via email, file transfer, storage card, etc.
Once the *.pfx file has been delivered to the
target device, the user must use the MobiControl applet running on the device to
import it. For further information, refer to the SSL Cert
tab in the mobile device configuration applet on importing the certificate.
(Please see the Mobile Device Configuration Applet page.
